Hiya,
I have just been playing around with a new Linux machine and the KDE Desktop.
Obviously, I tried the K-Suite as well.
KMail and KContact: No issues.
But with KOrganizer, the same old issue appeared again: No events to be seen, although the connection apparently is succesful.
Hello Google, my old friend…
After some digging, I found an older issue reported on the axigen.eu forum, where someone found issues in the main.ics file. So I though: Let’s curl this file and see if I can find something.
And there it is:
For reasons yet unknown:
Line 1:
BEGIN:VCALENDAR
Line 2174:
END:VCALENDAR
Line 2805:
END:VCALENDAR
=> Repeat 25 times with other line numbers.
So, I am not much of a programmer. But usually, if you BEGIN once, you END once.
In this case, throughout the main.ics file, I found 27 “END:VCALENDAR” entries.
I manually edited the main.ics file, removed all the “END:VCALENDAR” entries, but the last one and manually imported it into KOrganizer.
Tada … all appointments are there.
Common to all appointments with an “END:VCALENDAR” entry:
BEGIN:VEVENT
CLASS:PUBLIC
DESCRIPTION:\n\n
STATUS:CONFIRMED
SUMMARY:****
DTEND;TZID=Europe/Berlin:20171113T230000
DTSTART;TZID=Europe/Berlin:20171113T200000
TRANSP:OPAQUE
ORGANIZER:mailto:****
UID:040000008200E00074C5B7101A82E00800000000101D21F2464ED3010000000000000
000100000000652CC7991D3EB47AE4C106025362C19
CREATED:20180927T205122Z
DTSTAMP:20190711T102036Z
LAST-MODIFIED:20190711T102036Z
SEQUENCE:0
X-ALT-DESC:<html xmlns:v="urn:schemas-microsoft-com:vml" xmlns:o="urn:sch
emas-microsoft-com:office:office" xmlns:w="urn:schemas-microsoft-com:off
ice:word" xmlns:m="http://schemas.microsoft.com/office/2004/12/omml" xml
ns="http://www.w3.org/TR/REC-html40"><head><META HTTP-EQUIV="Content-Typ
e" CONTENT="text/html\; charset=us-ascii"><meta name=ProgId content=Word
.Document><meta name=Generator content="Microsoft Word 15"><meta name=Or
iginator content="Microsoft Word 15"><link rel=File-List href="cid:filel
ist.xml@01D34E46.DA5531D0"><!--[if gte mso 9]><xml>\n<o:OfficeDocumentSe
ttings>\n<o:AllowPNG/>\n</o:OfficeDocumentSettings>\n</xml><![endif]--><
!--[if gte mso 9]><xml>\n<w:WordDocument>\n<w:TrackMoves/>\n<w:TrackForm
atting/>\n<w:EnvelopeVis/>\n<w:PunctuationKerning/>\n<w:ValidateAgainstS
chemas/>\n<w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>\n<w:IgnoreMixed
Content>false</w:IgnoreMixedContent>\n<w:AlwaysShowPlaceholderText>false
</w:AlwaysShowPlaceholderText>\n<w:DoNotPromoteQF/>\n<w:LidThemeOther>EN
-GB</w:LidThemeOther>\n<w:LidThemeAsian>X-NONE</w:LidThemeAsian>\n<w:Lid
ThemeComplexScript>X-NONE</w:LidThemeComplexScript>\n<w:Compatibility>\n
<w:BreakWrappedTables/>\n<w:SnapToGridInCell/>\n<w:WrapTextWithPunct/>\n
<w:UseAsianBreakRules/>\n<w:DontGrowAutofit/>\n<w:SplitPgBreakAndParaMar
k/>\n<w:EnableOpenTypeKerning/>\n<w:DontFlipMirrorIndents/>\n<w:Override
TableStyleHps/>\n</w:Compatibility>\n<m:mathPr>\n<m:mathFont m:val="Camb
ria Math"/>\n<m:brkBin m:val="before"/>\n<m:brkBinSub m:val="-\;-"/>\
n<m:smallFrac m:val="off"/>\n<m:dispDef/>\n<m:lMargin m:val="0"/>\n<m:rM
argin m:val="0"/>\n<m:defJc m:val="centerGroup"/>\n<m:wrapIndent m:val="
1440"/>\n<m:intLim m:val="subSup"/>\n<m:naryLim m:val="undOvr"/>\n</m:ma
thPr></w:WordDocument>\n</xml><![endif]--><!--[if gte mso 9]><xml>\n<w:L
atentStyles DefLockedState="false" DefUnhideWhenUsed="false" DefSemiHidd
en="false" DefQFormat="false" DefPriority="99" LatentStyleCount="375">\n
<w:LsdException Locked="false" Priority="0" QFormat="true" Name="Normal"
/>\n<w:LsdException Locked="false" Priority="9" QFormat="true" Name="hea
ding 1"/>\n<w:LsdException Locked="false" Priority="9" SemiHidden="true"
UnhideWhenUsed="true" QFormat="true" Name="heading 2"/>\n<w:LsdExceptio
n Locked="false" Priority="9" SemiHidden="true" UnhideWhenUsed="true" QF
ormat="true" Name="heading 3"/>\n<w:LsdException Locked="false" Priority
="9" SemiHidden="true" UnhideWhenUsed="true" QFormat="true" Name="headin
g 4"/>\n<w:LsdException Locked="false" Priority="9" SemiHidden="true" Un
hideWhenUsed="true" QFormat="true" Name="heading 5"/>\n<w:LsdException L
ocked="false" Priority="9" SemiHidden="true" UnhideWhenUsed="true" QForm
at="true" Name="heading 6"/>\n<w:LsdException Locked="false" Priority="9
" SemiHidden="true" UnhideWhenUsed="true" QFormat="true" Name="heading 7
"/>\n<w:LsdException Locked="false" Priority="9" SemiHidden="true" Unhid
eWhenUsed="true" QFormat="true" Name="heading 8"/>\n<w:LsdException Lock
ed="false" Priority="9" SemiHidden="true" UnhideWhenUsed="true" QFormat=
"true" Name="heading 9"/>\n<w:LsdException Locked="false" SemiHidden="tr
ue" UnhideWhenUsed="true" Name="index 1"/>\n<w:LsdException Locked="fals
e" SemiHidden="true" UnhideWhenUsed="true" Name="index 2"/>\n<w:LsdExcep
tion Locked="false" SemiHidden="true" UnhideWhenUsed="true" Name="index
3"/>\n<w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="t
rue" Name="index 4"/>\n<w:LsdException Locked="false" SemiHidden="true"
UnhideWhenUsed="true" Name="index 5"/>\n<w:LsdException Locked="false" S
emiHidden="true" UnhideWhenUsed="true" Name="index 6"/>\n<w:LsdException
Locked="false" SemiHidden="true" UnhideWhenUsed="true" Name="index 7"/>
\n<w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true"
Name="index 8"/>\n<w:LsdException Locked="false" SemiHidden="true" Unhi
deWhenUsed="true" Name="index 9"/>\n<w:LsdException Locked="false" Prior
ity="39" SemiHidden="true" UnhideWhenUsed="true" Name="toc 1"/>\n<w:LsdE
xception Locked="false" Priority="39" SemiHidden="true" UnhideWhenUsed="
true" Name="toc 2"/>\n<w:LsdException Locked="false" Priority="39" SemiH
idden="true" UnhideWhenUsed="true" Name="toc 3"/>\n<w:LsdException Locke
d="false" Priority="39" SemiHidden="true" UnhideWhenUsed="true" Name="to
c 4"/>\n<w:LsdException Locked="false" Priority="39" SemiHidden="true" U
nhideWhenUsed="true" Name="toc 5"/>\n<w:LsdException Locked="false" Prio
rity="39" SemiHidden="true" UnhideWhenUsed="true" Name="toc 6"/>\n<w:Lsd
Exception Locked="false" Priority="39" SemiHidden="true" UnhideWhenUsed=
"true" Name="toc 7"/>\n<w:LsdException Locked="false" Priority="39" Semi
Hidden="true" UnhideWhenUsed="true" Name="toc 8"/>\n<w:LsdException Lock
ed="false" Priority="39" SemiHidden="true" UnhideWhenUsed="true" Name="t
oc 9"/>\n<w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed
="true" Name="Normal Indent"/>\n<w:LsdException Locked="false" SemiHidde
n="true" UnhideWhenUsed="true" Name="footnote text"/>\n<w:LsdException L
ocked="false" SemiHidden="true" UnhideWhenUsed="true" Name="annotation t
ext"/>\n<w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed=
"true" Name="header"/>\n<w:LsdException Locked="false" SemiHidden="true"
UnhideWhenUsed="true" Name="footer"/>\n<w:LsdException Locked="false" S
emiHidden="true" UnhideWhenUsed="true" Name="index heading"/>\n<w:LsdExc
eption Locked="false" Priority="35" SemiHidden="true" UnhideWhenUsed="tr
ue" QFormat="true" Name="caption"/>\n<w:LsdException Locked="false" Semi
Hidden="true" UnhideWhenUsed="true" Name="table of figures"/>\n<w:LsdExc
eption Locked="false" SemiHidden="true" UnhideWhenUsed="true" Name="enve
lope address"/>\n<w:LsdException Locked="false" SemiHidden="true" Unhide
WhenUsed="true" Name="envelope return"/>\n<w:LsdException Locked="false"
SemiHidden="true" UnhideWhenUsed="true" Name="footnote reference"/>\n<w
:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" Nam
e="annotation reference"/>\n<w:LsdException Locked="false" SemiHidden="t
rue" UnhideWhenUsed="true" Name="line number"/>\n<w:LsdException Locked=
"false" SemiHidden="true" UnhideWhenUsed="true" Name="page number"/>\n<w
e="endnote reference"/>\n<w:LsdException Locked="false" SemiHidden="true
" UnhideWhenUsed="true" Name="endnote text"/>\n<w:LsdException Locked="f
alse" SemiHidden="true" UnhideWhenUsed="true" Name="table of authorities
"/>\n<w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="tr
ue" Name="macro"/>\n<w:LsdException Locked="false" SemiHidden="true" Unh
ideWhenUsed="true" Name="toa heading"/>\n<w:LsdException Locked="false"
SemiHidden="true" UnhideWhenUsed="true" Name="List"/>\n<w:LsdException L
ocked="false" SemiHidden="true" UnhideWhenUsed="true" Name="List Bullet"
/>\n<w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="tru
e" Name="List Number"/>\n<w:LsdException Locked="false" SemiHidden="true
" UnhideWhenUsed="true" Name="List 2"/>\n<w:LsdException Locked="false"
SemiHidden="true" UnhideWhenUsed="true" Name="List 3"/>\n<w:LsdException
Locked="false" SemiHidden="true" UnhideWhenUsed="true" Name="List 4"/>\
Name="List 5"/>\n<w:LsdException Locked="false" SemiHidden="true" Unhide
WhenUsed="true" Name="List Bullet 2"/>\n<w:LsdException Locked="false" S
emiHidden="true" UnhideWhenUsed="true" Name="List Bullet 3"/>\n<w:LsdExc
eption Locked="false" SemiHidden="true" UnhideWhenUsed="true" Name="List
Bullet 4"/>\n<w:LsdException Locked="false" SemiHidden="true" UnhideWhe
nUsed="true" Name="List Bullet 5"/>\n<w:LsdException Locked="false" Semi
Hidden="true" UnhideWhenUsed="true" Name="List Number 2"/>\n<w:LsdExcept
ion Locked="false" SemiHidden="true" UnhideWhenUsed="true" Name="List Nu
mber 3"/>\n<w:LsdException Locked="false" SemiHidden="true" UnhideWhenUs
ed="true" Name="List Number 4"/>\n<w:LsdException Locked="false" SemiHid
den="true" UnhideWhenUsed="true" Name="List Number 5"/>\n<w:LsdException
Locked="false" Priority="10" QFormat="true" Name="Title"/>\n<w:LsdExcep
tion Locked="false" SemiHidden="true" UnhideWhenUsed="true" Name="Closin
g"/>\n<w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="t
rue" Name="Signature"/>\n<w:LsdException Locked="false" Priority="1" Sem
iHidden="true" UnhideWhenUsed="true" Name="Default Paragraph Font"/>\n<w
e="Body Text"/>\n<w:LsdException Locked="false" SemiHidden="true" Unhide
WhenUsed="true" Name="Body Text Indent"/>\n<w:LsdException Locked="false
" SemiHidden="true" UnhideWhenUsed="true" Name="List Continue"/>\n<w:Lsd
Exception Locked="false" SemiHidden="true" UnhideWhenUsed="true" Name="L
ist Continue 2"/>\n<w:LsdException Locked="false" SemiHidden="true" Unhi
deWhenUsed="true" Name="List Continue 3"/>\n<w:LsdException Locked="fals
e" SemiHidden="true" UnhideWhenUsed="true" Name="List Continue 4"/>\n<w:
LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" Name
="List Continue 5"/>\n<w:LsdException Locked="false" SemiHidden="true" U
nhideWhenUsed="true" Name="Message Header"/>\n<w:LsdException Locked="fa
lse" Priority="11" QFormat="true" Name="Subtitle"/>\n<w:LsdException Loc
ked="false" SemiHidden="true" UnhideWhenUsed="true" Name="Salutation"/>\
Name="Date"/>\n<w:LsdException Locked="false" SemiHidden="true" UnhideWh
enUsed="true" Name="Body Text First Indent"/>\n<w:LsdException Locked="f
alse" SemiHidden="true" UnhideWhenUsed="true" Name="Body Text First Inde
nt 2"/>\n<w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed
="true" Name="Note Heading"/>\n<w:LsdException Locked="false" SemiHidden
="true" UnhideWhenUsed="true" Name="Body Text 2"/>\n<w:LsdException Lock
ed="false" SemiHidden="true" UnhideWhenUsed="true" Name="Body Text 3"/>\
Name="Body Text Indent 2"/>\n<w:LsdException Locked="false" SemiHidden="
true" UnhideWhenUsed="true" Name="Body Text Indent 3"/>\n<w:LsdException
Locked="false" SemiHidden="true" UnhideWhenUsed="true" Name="Block Text
ue" Name="Hyperlink"/>\n<w:LsdException Locked="false" SemiHidden="true"
UnhideWhenUsed="true" Name="FollowedHyperlink"/>\n<w:LsdException Locke
d="false" Priority="22" QFormat="true" Name="Strong"/>\n<w:LsdException
Locked="false" Priority="20" QFormat="true" Name="Emphasis"/>\n<w:LsdExc
eption Locked="false" SemiHidden="true" UnhideWhenUsed="true" Name="Docu
ment Map"/>\n<w:LsdException Locked="false" SemiHidden="true" UnhideWhen
Used="true" Name="Plain Text"/>\n<w:LsdException Locked="false" SemiHidd
en="true" UnhideWhenUsed="true" Name="E-mail Signature"/>\n<w:LsdExcepti
on Locked="false" SemiHidden="true" UnhideWhenUsed="true" Name="HTML Top
of Form"/>\n<w:LsdException Locked="false" SemiHidden="true" UnhideWhen
Used="true" Name="HTML Bottom of Form"/>\n<w:LsdException Locked="false"
SemiHidden="true" UnhideWhenUsed="true" Name="Normal (Web)"/>\n<w:LsdEx
ception Locked="false" SemiHidden="true" UnhideWhenUsed="true" Name="HTM
L Acronym"/>\n<w:LsdException Locked="false" SemiHidden="true" UnhideWhe
nUsed="true" Name="HTML Address"/>\n<w:LsdException Locked="false" SemiH
idden="true" UnhideWhenUsed="true" Name="HTML Cite"/>\n<w:LsdException L
ocked="false" SemiHidden="true" UnhideWhenUsed="true" Name="HTML Code"/>
Name="HTML Definition"/>\n<w:LsdException Locked="false" SemiHidden="tr
ue" UnhideWhenUsed="true" Name="HTML Keyboard"/>\n<w:LsdException Locked
="false" SemiHidden="true" UnhideWhenUsed="true" Name="HTML Preformatted
ue" Name="HTML Sample"/>\n<w:LsdException Locked="false" SemiHidden="tru
e" UnhideWhenUsed="true" Name="HTML Typewriter"/>\n<w:LsdException Locke
d="false" SemiHidden="true" UnhideWhenUsed="true" Name="HTML Variable"/>
Name="Normal Table"/>\n<w:LsdException Locked="false" SemiHidden="true"
UnhideWhenUsed="true" Name="annotation subject"/>\n<w:LsdException Lock
ed="false" SemiHidden="true" UnhideWhenUsed="true" Name="No List"/>\n<w:
="Outline List 1"/>\n<w:LsdException Locked="false" SemiHidden="true" Un
hideWhenUsed="true" Name="Outline List 2"/>\n<w:LsdException Locked="fal
se" SemiHidden="true" UnhideWhenUsed="true" Name="Outline List 3"/>\n<w:
="Table Simple 1"/>\n<w:LsdException Locked="false" SemiHidden="true" Un
hideWhenUsed="true" Name="Table Simple 2"/>\n<w:LsdException Locked="fal
se" SemiHidden="true" UnhideWhenUsed="true" Name="Table Simple 3"/>\n<w:
="Table Classic 1"/>\n<w:LsdException Locked="false" SemiHidden="true" U
nhideWhenUsed="true" Name="Table Classic 2"/>\n<w:LsdException Locked="f
alse" SemiHidden="true" UnhideWhenUsed="true" Name="Table Classic 3"/>\n
<w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed="true" N
ame="Table Classic 4"/>\n<w:LsdException Locked="false" SemiHidden="true
" UnhideWhenUsed="true" Name="Table Colorful 1"/>\n<w:LsdException Locke
d="false" SemiHidden="true" UnhideWhenUsed="true" Name="Table Colorful 2
ue" Name="Table Colorful 3"/>\n<w:LsdException Locked="false" SemiHidden
="true" UnhideWhenUsed="true" Name="Table Columns 1"/>\n<w:LsdException
Locked="false" SemiHidden="true" UnhideWhenUsed="true" Name="Table Colum
ns 2"/>\n<w:LsdException Locked="false" SemiHidden="true" UnhideWhenUsed
="true" Name="Table Columns 3"/>\n<w:LsdException Locked="false" SemiHid
den="true" UnhideWhenUsed="true" Name="Table Columns 4"/>\n<w:LsdExcepti
on Locked="false" SemiHidden="true" UnhideWhenUsed="true" Name="Table Co
lumns 5"/>\n<w:LsdException Locked="false" SemiHidden="true" UnhideWhenU
sed="true" Name="Table Grid 1"/>\n<w:LsdException Locked="false" SemiHid
den="true" UnhideWhenUsed="true" Name="Table Grid 2"/>\n<w:LsdException
Locked="false" SemiHidden="true" UnhideWhenUsed="true" Name="Table Grid
rue" Name="Table Grid 4"/>\n<w:LsdException Locked="false" SemiHidden="t
rue" UnhideWhenUsed="true" Name="Table Grid 5"/>\n<w:LsdException Locked
="false" SemiHidden="true" UnhideWhenUsed="true" Name="Table Grid 6"/>\n
ame="Table Grid 7"/>\n<w:LsdException Locked="false" SemiHidden="true" U
nhideWhenUsed="true" Name="Table Grid 8"/>\n<w:LsdException Locked="fals
e" SemiHidden="true" UnhideWhenUsed="true" Name="Table List 1"/>\n<w:Lsd
Exception Locked="false" SemiHidden="true" UnhideWhenUsed="true" Name="T
able List 2"/>\n<w:LsdException Locked="false" SemiHidden="true" UnhideW
henUsed="true" Name="Table List 3"/>\n<w:LsdException Locked="false" Sem
iHidden="true" UnhideWhenUsed="true" Name="Table List 4"/>\n<w:LsdExcept
ion Locked="false" SemiHidden="true" UnhideWhenUsed="true" Name="Table L
ist 5"/>\n<w:LsdException Locked="false" SemiHidden="true" UnhideWhenUse
d="true" Name="Table List 6"/>\n<w:LsdException Locked="false" SemiHidde
n="true" UnhideWhenUsed="true" Name="Table List 7"/>\n<w:LsdException Lo
cked="false" SemiHidden="true" UnhideWhenUsed="true" Name="Table List 8"
e" Name="Table 3D effects 1"/>\n<w:LsdException Locked="false" SemiHidde
n="true" UnhideWhenUsed="true" Name="Table 3D effects 2"/>\n<w:LsdExcept
ion Locked="false" SemiHidden="true" UnhideWhenUsed="true" Name="Table 3
D effects 3"/>\n<w:LsdException Locked="false" SemiHidden="true" UnhideW
henUsed="true" Name="Table Contemporary"/>\n<w:LsdException Locked="fals
e" SemiHidden="true" UnhideWhenUsed="true" Name="Table Elegant"/>\n<w:Ls
dException Locked="false" SemiHidden="true" UnhideWhenUsed="true" Name="
Table Professional"/>\n<w:LsdException Locked="false" SemiHidden="true"
UnhideWhenUsed="true" Name="Table Subtle 1"/>\n<w:LsdException Locked="f
alse" SemiHidden="true" UnhideWhenUsed="true" Name="Table Subtle 2"/>\n<
X-SERVER-UID:5bad42c93749
X-MICROSOFT-CDO-BUSYSTATUS:busy
END:VEVENT
END:VCALENDAR
So, to me this looks like Outlook (O365, local, whatever…) adding this stuff and especially the “END:VCALENDAR” entries.
Is there any way to avoid this / repair the main.ics “inline” ?
JK
