Good day, everyone!
I am testing the current Docker (build 10.3.2 from Docker Hub ) which works great so far (running it on top of the swarm with an external smtp relay [postfix + rspamd]). Overall, I am very impressed with the solution, and really like its design and the effective simplicity.
Since I am running the “free version” and cannot use the Active Sync, I was wondering how to enable CardDAV and CalDAV - it seems that everything is enabled in the admin UI (and yes, I did restart the container after saving the config), I still cannot get the sync to run.
While accessing the WebDAV address on $FQDN, I do not see any calendars nor folders as described in the Axigen documentation (i.e. $FQDN/Contacts).
Any hints into the right direction?
Thanks in advance and best regards,
Denis
