I don’t know exactly how to describe it best - I’ll try it with an example.
My account at Axigen Mailserver is Test@test.com - since I have some other external mailboxes (Gmail/GMX/T-Online), I want to fetch them via RemotePOP. No problem so far.
But is it possible to use the respective senders under my Axigen account (i.e. test (at) gmail dot com & test (at) gmx dot de & test (at) t-online dot de)? For this I would have to create a separate SMTP relay host for each identity or set up a “routing” for it.
Is there any way Axigen can set this up somehow? Otherwise, remote POP makes relatively little sense, since I can never answer with the correct sender’s address.
Thanks a lot.
(forum-software blocks more than 2 links - and it recognizes my examples as links -> therefore with (at) and dot instead @.)
