I use windows server 2012 R2. I created the DNS DKIM records, following the documentation tutorial.
Doing the validation through these tools, says that everything is ok:
Administrative panel configuration:
In the test I did sending to my email, it ends up going to junk mail. Looking in the logs after sending, I find the following:
2021-02-21 02:32:05 +0100 16 vps159681 SMTP-IN:00000000: << SSL: client hello, remote 191.135.6.236:1739, version TLS 1.3 (0304)
2021-02-21 02:32:05 +0100 16 vps159681 SMTP-IN:00000000: << SSL: client hello, remote 191.135.6.236:1739, 21 cipher suites: c02cc02bc030c02f009f009ec024c023c028c027c00ac009c014c013009d009c003d003c0035002f000a
2021-02-21 02:32:05 +0100 16 vps159681 SMTP-IN:00000000: << SSL: client hello, remote 191.135.6.236:1739, sni extension for mail.multicoisastore.com.br
2021-02-21 02:32:05 +0100 16 vps159681 SMTP-IN:00000000: >> SSL: server hello, remote 191.135.6.236:1739, version TLS 1.2 (0303)
2021-02-21 02:32:05 +0100 16 vps159681 SMTP-IN:00000000: >> SSL: server hello, remote 191.135.6.236:1739, cipher suite c02f
2021-02-21 02:32:05 +0100 16 vps159681 SMTP-IN:00000000: >> SSL: server write cert, remote 191.135.6.236:1739, version TLS 1.2 (0303)
2021-02-21 02:32:05 +0100 16 vps159681 SMTP-IN:00000000: >> SSL: server write cert, remote 191.135.6.236:1739, certificate 1: serial 04774C19E78823186B5491FC227B89A9A156
2021-02-21 02:32:05 +0100 08 vps159681 SMTP-IN:000002A9: [151.80.130.233:465] connection accepted from [191.135.6.236:1739]
2021-02-21 02:32:05 +0100 16 vps159681 SMTP-IN:000002A9: >> 220 vps159681 Axigen ESMTP ready
2021-02-21 02:32:06 +0100 16 vps159681 SMTP-IN:000002A9: << EHLO BrunoDesktop
2021-02-21 02:32:06 +0100 08 vps159681 SMTP-IN:000002A9: Set remote delivery to auth
2021-02-21 02:32:06 +0100 08 vps159681 SMTP-IN:000002A9: Greylist enabled
2021-02-21 02:32:06 +0100 08 vps159681 SMTP-IN:000002A9: Set max data size to 10240 KB
2021-02-21 02:32:06 +0100 08 vps159681 SMTP-IN:000002A9: Set max received headers to 30
2021-02-21 02:32:06 +0100 08 vps159681 SMTP-IN:000002A9: Maximum recipient count set to 1000
2021-02-21 02:32:06 +0100 08 vps159681 SMTP-IN:000002A9: Wait for processing response at least 10 seconds
2021-02-21 02:32:06 +0100 08 vps159681 SMTP-IN:000002A9: STARTTLS extension allowed
2021-02-21 02:32:06 +0100 08 vps159681 SMTP-IN:000002A9: 8BIT MIME accepted
2021-02-21 02:32:06 +0100 08 vps159681 SMTP-IN:000002A9: BINARY DATA extension allowed
2021-02-21 02:32:06 +0100 08 vps159681 SMTP-IN:000002A9: PIPELINING extension allowed
2021-02-21 02:32:06 +0100 08 vps159681 SMTP-IN:000002A9: DSN extension denied
2021-02-21 02:32:06 +0100 08 vps159681 SMTP-IN:000002A9: Set local delivery to all
2021-02-21 02:32:06 +0100 16 vps159681 SMTP-IN:000002A9: >> 250-vps159681 Axigen ESMTP hello
2021-02-21 02:32:06 +0100 16 vps159681 SMTP-IN:000002A9: >> 250-PIPELINING
2021-02-21 02:32:06 +0100 16 vps159681 SMTP-IN:000002A9: >> 250-AUTH PLAIN LOGIN CRAM-MD5 DIGEST-MD5 GSSAPI
2021-02-21 02:32:06 +0100 16 vps159681 SMTP-IN:000002A9: >> 250-AUTH=PLAIN LOGIN CRAM-MD5 DIGEST-MD5 GSSAPI
2021-02-21 02:32:06 +0100 16 vps159681 SMTP-IN:000002A9: >> 250-8BITMIME
2021-02-21 02:32:06 +0100 16 vps159681 SMTP-IN:000002A9: >> 250-BINARYMIME
2021-02-21 02:32:06 +0100 16 vps159681 SMTP-IN:000002A9: >> 250-CHUNKING
2021-02-21 02:32:06 +0100 16 vps159681 SMTP-IN:000002A9: >> 250-SIZE 10485760
2021-02-21 02:32:06 +0100 16 vps159681 SMTP-IN:000002A9: >> 250-HELP
2021-02-21 02:32:06 +0100 16 vps159681 SMTP-IN:000002A9: >> 250 OK
2021-02-21 02:32:06 +0100 16 vps159681 SMTP-IN:000002A9: << AUTH DIGEST-MD5
2021-02-21 02:32:06 +0100 16 vps159681 SMTP-IN:000002A9: >> 334 bm9uY2U9IlU1SndOak9UczN5TlNDREgzakYvZUNheWE0UHYxQzNDaWgzQkwwK1BFQVU9IixyZWFsbT0idnBzMTU5NjgxIixxb3A9ImF1dGgiLGNoYXJzZXQ9dXRmLTgsYWxnb3JpdGhtPW1kNS1zZXNz
2021-02-21 02:32:06 +0100 16 vps159681 SMTP-IN:000002A9: << SASL client response
2021-02-21 02:32:06 +0100 16 vps159681 SMTP-IN:000002A9: >> 334 cnNwYXV0aD0wOWE0MmQ1ZDJjYmE1YzU3NjIyOTZhYzAyMTMwYjhiNQ==
2021-02-21 02:32:07 +0100 16 vps159681 SMTP-IN:000002A9: << SASL client response
2021-02-21 02:32:07 +0100 16 vps159681 SMTP-IN:000002A9: >> 235 Authentication successful
2021-02-21 02:32:07 +0100 08 vps159681 SMTP-IN:000002A9: session from [191.135.6.236] authenticated by <contato@multicoisastore.com.br>
2021-02-21 02:32:07 +0100 16 vps159681 SMTP-IN:000002A9: << MAIL FROM: <contato@multicoisastore.com.br>
2021-02-21 02:32:07 +0100 08 vps159681 SMTP-IN:000002A9: Created new queue item with id 001C5E8C
2021-02-21 02:32:07 +0100 08 vps159681 SMTP-IN:000002A9: SPF result for MAIL FROM <contato@multicoisastore.com.br@multicoisastore.com.br> issued from EHLO domain <BrunoDesktop> connected from <191.135.6.236>: Pass (spfHeader = ''; spfExplanation = 'SPF pass for authenticated connection')
2021-02-21 02:32:07 +0100 16 vps159681 SMTP-IN:000002A9: >> 250 Sender accepted
2021-02-21 02:32:07 +0100 16 vps159681 SMTP-IN:000002A9: << RCPT TO: <raibom@hotmail.com>
2021-02-21 02:32:07 +0100 16 vps159681 SMTP-IN:000002A9: >> 250 Recipient accepted
2021-02-21 02:32:07 +0100 16 vps159681 SMTP-IN:000002A9: << DATA
2021-02-21 02:32:07 +0100 08 vps159681 SMTP-IN:000002A9: Skip greylist for authenticated session
2021-02-21 02:32:07 +0100 16 vps159681 SMTP-IN:000002A9: >> 354 Ready to receive data; remember <CRLF>.<CRLF>
2021-02-21 02:32:08 +0100 16 vps159681 SMTP-IN:000002A9: << 8149 bytes read
2021-02-21 02:32:08 +0100 16 vps159681 SMTP-IN:000002A9: << 23699 bytes and final dot read
2021-02-21 02:32:08 +0100 08 vps159681 SMTP-IN:000002A9: DomainKeys verification result: no signature
2021-02-21 02:32:08 +0100 08 vps159681 SMTP-IN:000002A9: DKIM verification result: no signature
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Shepherd thread received signal for processing
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Set recipient <raibom@hotmail.com> state to RECEIVED
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Set mail state to PROCESSING
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Start processing mail
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Set recipient <raibom@hotmail.com> state to PROCESSING
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Start filter AV:Tnef of type socket filter from server
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Processing started
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Shepherd thread finished processing signal
2021-02-21 02:32:08 +0100 16 vps159681 PROCESSING:001C5E8C: << welcome to Axigen TNEF Decoder (1.2.0)
2021-02-21 02:32:08 +0100 16 vps159681 PROCESSING:001C5E8C: >> filter|
2021-02-21 02:32:08 +0100 16 vps159681 PROCESSING:001C5E8C: >> C:\Axigen Mail Server\\queue\1C\D5E8C.00
2021-02-21 02:32:08 +0100 16 vps159681 PROCESSING:001C5E8C: >> |
2021-02-21 02:32:08 +0100 16 vps159681 PROCESSING:001C5E8C: >> C:\Axigen Mail Server\\queue\1C\D5E8C.01
2021-02-21 02:32:08 +0100 16 vps159681 PROCESSING:001C5E8C: << done
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Filter AXI-TNEF(127.0.0.1:8888):[PASS]: pass - no changes
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Finished filtering mail object 1C5E8C with filter: AV:Tnef of type socket filter from server
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Set recipient <raibom@hotmail.com> data version to 1
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Start filter onProcessing event
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: The message has been signed using DomainKeys
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: The message has been signed using DKIM
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Finished filtering mail object 1C5E8C with filter: onProcessing event
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Set recipient <raibom@hotmail.com> data version to 2
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Set recipient <raibom@hotmail.com> state to PROCESSED - RELAY
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Set mail state to PROCESSED
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Processing finished
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Shepherd thread received signal for delivery
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Shepherd thread finished delivery signal
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Start mail delivery
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Set mail state to SENDING
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Start remote delivery for 1 recipients in domain hotmail.com
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Use plain connection
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: STARTTLS extension allowed
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Allowed ssl versions set to: tls11 tls12 tls13
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Relay mail using default host: <hotmail.com:25>
2021-02-21 02:32:08 +0100 08 vps159681 DNR:001C5E8C: Search MX for 'hotmail.com'
2021-02-21 02:32:08 +0100 08 vps159681 DNR:001C5E8C: Sending query (1/1) to 208.67.222.222:53
2021-02-21 02:32:08 +0100 08 vps159681 DNR:001C5E8C: 'hotmail-com.olc.protection.outlook.com' found MX '104.47.55.33' with priority 2
2021-02-21 02:32:08 +0100 08 vps159681 DNR:001C5E8C: 'hotmail-com.olc.protection.outlook.com' found MX '104.47.58.33' with priority 2
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Relay mail: found IPv4 MX entry 104.47.55.33 for domain hotmail.com with priority 2
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Relay mail: found IPv4 MX entry 104.47.58.33 for domain hotmail.com with priority 2
2021-02-21 02:32:08 +0100 08 vps159681 PROCESSING:001C5E8C: Use 104.47.58.33 to relay mail 1C5E8C for domain hotmail.com
2021-02-21 02:32:08 +0100 08 vps159681 SMTP-OUT:00000008: Relay mail 1C5E8C: connecting to 104.47.58.33:25
2021-02-21 02:32:09 +0100 08 vps159681 SMTP-OUT:00000008: Relay mail 1C5E8C: connected to 104.47.58.33:25
2021-02-21 02:32:09 +0100 02 vps159681 SMTP-OUT:00000008: SSL error remote 104.47.58.33:25, SSL_connect:failed in SSLv3/TLS write client hello
2021-02-21 02:32:09 +0100 02 vps159681 SMTP-OUT:00000008: SSL error remote 104.47.58.33:25, SSL_connect:failed in SSLv3/TLS write finished
2021-02-21 02:32:09 +0100 08 vps159681 SMTP-OUT:00000008: Start sending mail 1C5E8C
2021-02-21 02:32:09 +0100 08 vps159681 SMTP-OUT:00000008: Release mail 1C5E8C
2021-02-21 02:32:10 +0100 08 vps159681 SMTP-OUT:00000008: Release mail 1C5E8C
2021-02-21 02:32:10 +0100 08 vps159681 SMTP-OUT:00000008: Data sent for mail 1C5E8C; server response: 2.6.0 <008701d707f9$c06a6bd0$413f4370$@multicoisastore.com.br> [InternalId=5665061883239, Hostname=DM6NAM10HT124.eop-nam10.prod.protection.outlook.com] 41234 bytes in 0.313, 128.350 KB/sec Queued mail for delivery -> 250 2.1.5
2021-02-21 02:32:10 +0100 08 vps159681 SMTP-OUT:00000008: Set recipient <raibom@hotmail.com> state to SENT
2021-02-21 02:32:10 +0100 08 vps159681 SMTP-OUT:00000008: Delivery attempt completed for mail 1C5E8C; schedule for cleanup
2021-02-21 02:32:10 +0100 08 vps159681 SMTP-OUT:00000008: Set mail state to SENT
2021-02-21 02:32:10 +0100 08 vps159681 PROCESSING:001C5E8C: Shepherd thread received signal for cleanup
2021-02-21 02:32:10 +0100 08 vps159681 PROCESSING:001C5E8C: Start mail cleanup
2021-02-21 02:32:10 +0100 08 vps159681 PROCESSING:001C5E8C: Mail removed from queue
2021-02-21 02:32:10 +0100 08 vps159681 PROCESSING:001C5E8C: Set mail state to REMOVED
2021-02-21 02:32:10 +0100 08 vps159681 SMTP-IN:000002A9: New mail <008701d707f9$c06a6bd0$413f4370$@multicoisastore.com.br> received from BrunoDesktop (191.135.6.236) with envelope from <contato@multicoisastore.com.br>, authenticated as <contato@multicoisastore.com.br>, recipients=1 (raibom@hotmail.com), size=31842, enqueued with id 1C5E8C
2021-02-21 02:32:10 +0100 16 vps159681 SMTP-IN:000002A9: >> 250 Mail queued for delivery
2021-02-21 02:32:10 +0100 08 vps159681 PROCESSING:001C5E8C: Shepherd thread finished cleanup signal
2021-02-21 02:32:10 +0100 08 vps159681 SMTP-OUT:00000008: Disconnected from 104.47.58.33
2021-02-21 02:32:12 +0100 08 vps159681 IMAP:000002AB: [151.80.130.233:993] connection accepted from [191.135.6.236:1754]
2021-02-21 02:32:13 +0100 16 vps159681 SMTP-IN:000002A9: << QUIT
2021-02-21 02:32:13 +0100 16 vps159681 SMTP-IN:000002A9: >> 221-vps159681 Axigen ESMTP is closing connection
2021-02-21 02:32:13 +0100 16 vps159681 SMTP-IN:000002A9: >> 221 Good bye
2021-02-21 02:32:13 +0100 08 vps159681 SMTP-IN:000002A9: closing session from [191.135.6.236:1739]
2021-02-21 02:32:13 +0100 08 vps159681 IMAP:000002AB: User [contato@multicoisastore.com.br] successfully authorized!
2021-02-21 02:32:17 +0100 08 vps159681 JOBLOG:B0000038: contato+Sent@multicoisastore.com.br[headers]: Sort index update finished (1 inserts, 0 deletes, 0 updates, 15.317310 ms)
2021-02-21 02:32:18 +0100 08 vps159681 WEBADMIN:00000296: Session 0x682CCE44 associated with this connection
2021-02-21 02:32:21 +0100 08 vps159681 JOBLOG:8200002C: Finished updating mail index for user contato@multicoisastore.com.br (1 inserts, 0 updates, 0 deletes, 0 folder deletes, 0 optimizations, 0 vacuums, 26.309768 ms)
2021-02-21 02:32:23 +0100 08 vps159681 WEBADMIN:00000299: Session 0x682CCE44 associated with this connection
2021-02-21 02:32:25 +0100 08 vps159681 WEBADMIN:0000029A: previous line is repeated 4294967295 time.
2021-02-21 02:32:25 +0100 08 vps159681 WEBADMIN:0000029A: Session 0x682CCE44 associated with this connection
What intrigues me is the information:
As I understand it, DKIM is not being used. That’s right? I would like help.
Thanks.
