Question relatted to docker-compose and running such images
I have a following question related to running images prepated by docker-compose.
Assuming that the compose file shares some ports (and does propper mapping) then while running the image with docker, do I need to list (again) same ports as in the compose file using the “-p” parameter?
Hello @mcgiwer
If you are using the docker compose example from our website the ports mapping are included in the composer yaml file and you do not need to use “-p” option:
networks:
  axi-network:
    driver: bridge
services:
  axigen:
    image: axigen/axigen
    ports:
      - "80:80"
      - "443:443"
      - "993:993"
      - "995:995"
      - "25:25"
      - "465:465"
      - "7000:7000"
      - "9000:9000"
      - "9443:9443"
    volumes:
      - "<volume>:/axigen/var"
    networks:
      - axi-network
And start the the container using:
docker compose up
