One of the main reasons that I chose AXIGEN was because it had a nicer built-in webmail client than other servers. Installing an actual local software email client is old school, and takes up too much drive space and just creates another point of potential failure. I dont need more issues to troubleshoot.
However, the more I use AXigen webmail, the more I find it lacking:
NO Column Titles / Grid Headders at the top of the email list. (To, FROM, SUBJECT, SIZE)
NO ability to SORT emails by column (To, FROM, SUBJECT, SIZE)
NO ablity to edit/rename an email subject
NO ability to “tag” an email with a category (and then sort on it)
NO ability to natively dedupe contacts
PLEASE PLEASE PLEASE add these features!! And SOON!
I could only confirm that 99.99% there will be no native mobile app for Axigen server (not 100% as it is said that “never say never” )
My advice is to get used with the “stripped down” interface available through the mobile browsers. In case you have not yet activated it you could do it from WebAdmin > Services > Mobility & Sync > Enable Mobile WebMail.
