For -m option please review the available options you may set for Axigen, like:
# ./axigen --help
Usage: axigen [option...[value...]]
Flags:
-h, --help Print this help.
-v, --version Print version and exit.
-V, --fullversion Print full version, including libs, and exit.
Options:
--foreground Run in foreground.
--drop-core path Full path (240 maximum length) to an existing directory where to drop core. Default is not set.
-W, --workdir path Full path (240 maximum length) to working directory. Default to /var/opt/axigen/.
-C, --configfile filename Server configuration file. Default to 'workdir'/run/axigen.cfg.
-L, --license filename Server license key (LK) binary file. Default to 'workdir'/axigen_lk.bin.
-A, --admin-passwd password Set the `admin` password in server registry and exit.
-K, --check-configuration Check configuration files, report errors and exit.
-u, --user username User's name who executes the server. Default to 'axigen'.
-g, --group groupname Group's name who executes the server. Default to 'axigen'.
--ulimit-n Min=1024, Max=100000 Maximum number of open file descriptors. Default to 20000.
-m, --ulimit-v Min=512 Virtual memory limit in MB. Default to 0 (inherited from environment).
--mem-reserve Min=12, Max=1024 Memory used by memory manager module in MB. Default to 200.
--max-respawns Min=0, Max=30 Maximum number of accepted faulty processes per minute before exiting. Default to 10.
--gen-cert certpath [dhpath] Generates a self-signed certificate and optional a Diffie-Hellman key.
--gen-cert-cn certificate CN The Common Name of SSL certificate.
--rmtuning level Configure resource manager behavior. Possible values: lazy, normal, aggressive, paranoia.
--large-stream-support enabled, disabled or read-only Configure large stream support in storage.
--stop-timeout seconds Maximum time to wait for a child process to stop.
--alloc-library filename The library containing memory allocation functio
Basically, when using -m 4096 you will limit Axigen memory consumption to 4 GB.
For MALLOC_ARENA_MAX, this is an environment variable specific to GLIBC - more information here, here and here.
I’m not sure where you get that max value for -m option is 4095 - most probably is an old documentation that we need to update it therefor any hints here will be appreciated.
Regarding the malloc specific variable you may leave with the mentioned value (4).
